Manuel d'utilisation Olympus 35RC
Olympus 35 RC Instructions
olympus35rc (39K)
GREAT IMPORTANCE!
  1. Be sure to use the Shutter Speed Numbers only when the Shutter Speed Dial clicks into position at the black index mark.
  2. In the following cases of automatic exposure, the Shutter Release Button is automatically locked and cannot be depressed.
    • When it is either under-exposure or over-exposure.
    • When the Shutter Speed Dial is set to the B (for bulb) position.
    • When no mercury battery is loaded.
    • When the F/stop Ring is set to the Off position either in automatic or manual exposure.
You Can't Miss The Moment - either Automatic or Manual.
On automatic you just set the speed then the camera determines the right aperture setting. The shutter release locks when the light is insufficient. In flash photography, the 35RC automatically determines the aperture opening as you focus. In manual operation, shutter speed and aperture setting combinations are at your discretion.
On either automatic or manual the easy-to-view double image coupled rangefinder gives you sharp, crisp, pictures. And you can read your shutter and aperture settings in the viewfinder. Olympus engineering designed in a handy self-timer.
Black and white or colour, your full-frame 35mm Olympus 35RC will let you enjoy perfect photography with every click of the shutter.
olympus35rc-3 (20K)
olympus35rc-4 (47K)
olympus35rc-5 (41K)
Un conseil sur l'Olympus 35RC?
--> Forum télémétriques
